Страничка на официальном сайте
Main Features and Specifications
LED: CREE XLamp XR-E Q5
Light Output: Constant ratio output level spread. Current regulated.
96 Lumens (2.3 hr) on High
18 Lumens (19 hr) on Medium
3.3 Lumens (3.5 days) on Low
Beam Type: 80 degree flood, with no hotspot
Battery: One AA size alkaline, 1.5v lithium primary, NiMH rechargeable, or 3.7v 14500 Li-ion rechargeable. Reverse polarity protection.
Dimensions
Diameter 18.5 mm (3/4”)
Height 71.2 mm (2 3/4”)
Constructions
Soft touch pushbutton switch, with a minimum operating life of one million cycles.
Recessed impact resistant LEXAN polycarbonate lens.
Precision 3D machined casing from premium grade Alcoa aluminum alloy billet, light weight with superior structural strength.
Electrically conductive aluminum body provides inherent EMI/RFI shielding.
Durable hard anodized finish.
Waterproof
Meets IP68 in accordance with IEC 60529
Dust-tight
Protected against continuous immersion (1 meter, >30 minutes)
Operations
From Off
Press and hold to cycle through Low, Med and High, release to set.
Click to High, click again quickly to cycle through Med, Low and High.
When On
Click to Off.
