Что такое Пистондрайв?
- Aleksandr Afonchenko
- Afonchenko Knives
Коллеги извиняюсь, прошу прощения можно сцылку на фото этой вещи? что оно такое это пистон драйв?
И что в ней класного?
Re: Емае что такое Пистондрайв?
Now a little bit about the Smart PD System.
Why Piston Drive?
We think's Don's piston design is just cool and pure genius. It's an excellent solution for pure momentary applications yet it also serves as a "twisty" light. The Smart PD system retains these two important features.
There is nothing cooler knowing how the piston works as you pressing the tail and "interacting" with the head of the light.
It also accomplishes two things:
1) It takes the current path out of the casing for the light. Electricity travels through the piston instead of the exterior casing. This is advantageous in certain applications. 2) Secondly, it moves the switching mechanism to the front of the light and increases the "contact area" where the circuit is completed, thus increasing it's reliability.
Why is the increased contact area so important?
It is a little known yet very serious problem with MOST clicky lights is that they are prone to fail due to the design of the clicky switches. (This has found to be the case even in high-end expensive $200+ lights!) This is because these clicky switches were never designed to handle heavy current loads in the first place. They are "signal" switches and not designed to carry current. Most lights using these switches often take over one amp of current. Each time the clicky is cycled, the contacts build up a little "carbon" and the switch begins to build up resistance and will ultimately fail. It is very obvious when you open up one of these switches and study the actual tiny contact points. When a switch handles more current than it is designed to take then it is not a matter of "if" but of "when" the switch will fail AND how lucky you are
We don't want any part of luck when it comes to your light turning on.
That is usually not a problem with consumer grade flashlights not designed for daily duty. However, in mission critical situations, the last thing you want is a failed switch. The PD design solves this problem. The Smart PD system actually switches on electronically, so the actual contact between the piston and the head is even more reliable. The higher current is applied microseconds AFTER the piston has made contact.
So whats so special about the "SMART" PD?
The Smart PD System inherits all the basics of Don's PD (except for the two stage output based on the piston pressure). It's very simple. Twist the head tight, it turns on. Loosen the head, it turns off. You don't even have to touch the piston. It doesn't get any simpler than that - it's a basic twisty.
While the head is loosened, you depress the piston in the tail and the light comes on. Release it and it turns OFF. Pure tactical momentary. Beautiful. We can just stop here since this is probably what 90% of what people use to turn their lights on
Ok... So if you want it to operate as if it has a clicky tail - Tighten the head and the light turns ON. "CLICK" the piston and it turns off. "CLICK" again and it turns on. (a "CLICK" is defined as a quick push and release of the piston within 0.3 seconds) It's beautifully simple. The action is quiet compared to traditional clickies. There is no latching mechanism like in a clicky switch - it's all handled by the microprocessor in the head of the light.
Ready for something more? While the light is on, "PRESS" and hold the piston and it ramps up the brightness to maximum. Now release it and "PRESS" again will ramp it down to minimum. The ramping action stops when you release the piston. (a "PRESS" is defined as pushing the piston longer than 0.3 seconds)
There are 100 levels of output to choose from - more than ample to suit ANY task. The Smart PD will remember your last output setting in memory. So if you click off and click back on, it will come on at your last setting. Genius.
Say you want instant access to MINIMUM or MAXIMUM output. It's a piece of cake. While the light is ON, do a "CLICK-CLICK" and it jumps to the MINIMUM. Or a "CLICK-PRESS" and it jumps to MAXIMUM.
Or if you want to get to those extreme outputs while the light is OFF: "CLICK-CLICK-CLICK" jumps to MINIMUM and "CLICK-CLICK-PRESS" jumps to MAXIMUM.
Why Piston Drive?
- Afonchenko Knives
УУУ все понятно, а на видео явный фан найткоров )
Да уж как я отсал
Кстати как она в работе эта система?
Я о мнении пользовавшихся ?
Да уж как я отсал
Отлично в работе.
На мой взгляд это самый лучший интерфейс на сегодняшний день.
Я очень доволен
Я очень доволен
Вообще-то представитель компанииCodename 47 писал(а):а на видео явный фан найткоров
Но в любом случае не вижу ничего неадекватного, т.к. Найткоры с пистондрайвом и Зебры - это лучшее, что было в этом году в мире фонарестроения
7 сообщений
