На офсайте - http://www.viper.it/en/tattica/free.html
Три варианта цвета накладок, клинок с покрытием или без.
Масса: 123 гр.
Общая длина: 210 мм
Длина клинка: 86 мм
Design by Moreno Franzin e Tommaso Rumici
With the Free we achieved a new milestone in the safety field. Our new Smartlock® system, used for the first time on this folder, solves every problem that can impact the classic liner-lock structural design. Furthermore, thanks to its handy spinal slide, the user can choose to completely block the mechanism. To close the blade down the slide has to be brought back to its initial position.
Specifications:
FOLDING KNIFE
Blade: AISI D2 tool steel; vacuum heat treated, dual phase tempering, cryogenic heat treatment; thickness 3,6 mm; hardness HRC 58/60; PVD or Stone washed finishing.
Handle: Black / Brown / Green G-10.
Scale: fixed and rocking parts in AISI 420C tempered steel.
Slide: hard anodised 6026 aluminium.
Screws/pivot screw: AISI 303 stainless steel.
Clip: Tempered stainless steel; satin finished.
Mechanism: new Smart Lock® mechanism (Patent PCT/IT2012/00283).
