Самая крупная ZEBRA?!
Фонари и аксессуары от ZebraLight
спайдодыр
Благодарил (а): 961 раз
Сообщение спайдодыр »
Вот наткнулся случайно на такого карманного монстра:http://www.zebralight.com/S6330-Triple- ... p_104.html
Если правильно понял,это из новинок,ещё не обсуждавшихся.
LED: Cree XM-L Cool White (Norminal CCT 6300K)
User Selectable Levels: 3 main level (High, Medium and Low). Each main level can be configured to one of its two sub-levels. The second sub-level of the High (H2) can be further configured to different brightness levels or strobes.
Light Output
High
H1 2400Lm (temperature regulated output, typical runtime 2 hrs, runtime varies greatly with ambient temperature) or
H2 1100Lm (temperature regulated output, typical runtime 3 hrs, runtime varies greatly with ambient temperature) / 400Lm (11 hrs) / 4Hz Strobe
Medium
M1 260Lm (16 hrs) or
M2 75Lm (62 hrs) / 24Lm (8 days)
Low
L1 5.7Lm (26 days) or
L2 1.9Lm (11 weeks) / 0.43Lm (7 months) / 0.09Lm (1 year)
Runtimes are tested using ZebraLight ZL631 batteries. Light output are ANSI out the front (OTF) values. All levels are current regulated.
Operating Voltage Range: 2.7V - 4.2V
Battery: One to three 18650 size (up to 68mm long) 3.6/3.7V Li-ion rechargeable battery. Batteries are not included in the package.
Parasitic Drain: Negligible (much less than the self discharging of batteries)
Beam Type
80 degree spill
10 degree hot spot
Dimensions
Head Diameter: 2.24 inch (57 mm)
Length: 4.14 inch (105 mm)
Weight
10 oz (283 gram)
Features
Lanyard ring
Three independent battery power channel for ultimate battery safty and flexibility (mix and match any 1-3 batteries)
Temperature regulated ouput automatically adjust output levels based on ambient temperature
Automatically stepping down from High to Medium, and from Medium to Low when battery capacity is low
Builtin over-discharging protection with 2.7V cutoff
Electronic soft-touch switch
Smart user interface provides fast and easy access to all brightness levels
Precision machined casing from premium grade aluminum
Durable natural hard anodized finish (Type III Class I)
Ultra clear lens with anti-reflection coatings on both sides
Orange peel textured reflector, with exactly the same profile as the SC600 reflector
Battery reverse polarity protection
Waterproof to IPX7 (2 meters, 30 minutes)
Operations
This light has 3 main levels (High, Medium, and Low). Each main level can be configured to one of its two sub-levels. The second sub-level of each main level can be further configured to different brightness levels or strobes.
Basic Operation
Short click turns on the light to High or turns off the light.
Long click (press and hold for about 0.7 seconds) turns on the light to Low.
Advanced Operation and Configuration
Short click turns on the light to High. Short click again quickly to cycle from High to Medium, and Low.
Press and hold to cycle from Low to High, release to set. When press and hold, the light always cycle from Low to High regardless which level you are currently in.
Double click to toggle and select between the two sub-levels for that main level. Sub-level selections (except the strobe) for the 3 main levels are memorized after the light is turned off and through battery changes.
The second sub-level of each main levels can be configured after 6 double clicks. Double click (startng with the 7th) to cycle and select different brightness levels or strobes. Short click to turn off the light when finishing configurations. The selections for the second sub-level are memorized after the light is turned off and through battery changes.
This light uses the LEDs to indicate the estimated remaining battery capacity by flashing 1 to 4 times. To start the battery indicator, short-click 4 times without pause from OFF.
Работает от 3-х :shock: аккумуляторов 18650 Максималка 2400Лм!!!Можно нехило посветить под ноги :evil:
dai
Re: Самая крупная ZEBRA?!
Сообщение dai »
Какие ноги.... Там свет будет сильнее чем дальний ксенон у машины!!!
Mio
Сообщение Mio »
Клевая болванка, такой метнуть в голову супостата нехило можно)))
Благодарил (а): 717 раз
Не знаю, какая зёбра самая крупная, но самая известная - эта:
Rocket Dog
Сообщение Rocket Dog »
На буржуйских форумах уже вовсю обсуждают. Бимшоты по ссылкам.
http://www.candlepowerforums.com/vb/sho ... ing/page24
http://www.taschenlampen-forum.de/zebra ... 330-3.html
Подождем обзоров на фонаревке, отзывов о надежности этой печки, и можно брать :-)
himeraha
Благодарил (а): 11 раз
Сообщение himeraha »
прожектор.
спайдодыр
Вес указан без аккумов?Почти 300гр.-многовато для десятисантиметрового фонарика.А так,вообще,прикольная игрушка получилась rt24
vaclav
Сообщение vaclav »
спайдодыр писал(а):Вес указан без аккумов?Почти 300гр.-многовато для десятисантиметрового фонарика.
Imho не для пешего туризма. Брал такого типа фонарик в поездку 3*18650, 1*XML:
а) Отлично и долго подсвечивал ломавшийся рейсовый автобус (мотор). Чтоб он себе протыкал все 4 колеса каждый месяц - до места назначения нас не довез.
б) Фонарь (точнее - батареи) слишком тяжелый чтобы брать с собой в рюкзак когда ходишь по городу. За день - выматывает.
soe
Сообщение soe »
vaclav писал(а):Imho не для пешего туризма
в машину - супер
Вернуться в «ZebraLight»
