сравнение выкрашивания zpd-189 s30v 52100 420HC (eng)
Тесты ножей и инструмента
__Z V I R__
Сообщение __Z V I R__ »
коллега из бруклина порезал спортивные тапки и посмотрел что с этого станется ножам. результаты выложил на блйдфоруме и спайдерфоруме, за что ему спасибо.
*disclaimer: i went into this test willing to except responsibility for ruining/damaging my knives and/or myself.
if anyone tries to recreate this test they must also except that responsibility.*
*this is in no way a scientific test or 100% accurate. all tests were real world and as is, using sneakers taken directly from my hallway.
im not perfect, but i tried my best to keep everything as close as possible.
this is just one specific type of test and in no way should it be used to "try" and disprove or discredit other well done tests.
this is just another small piece in a very large steel puzzle.*
i decided to take a few different knives/steels i have and cut up some of my old, size-12 new balance's (US made).
i cut each sneaker into approximately 26-28 pieces, to keep the test as fair as possible
all blades tested so far are between 3"-4" long and less than 4mm at the thickest part of the spine.
all edges are about 18-20 degrees per side (i hand sharpen but i'm pretty accurate).
all knives were beveled, sharpened and finished on the same stones.
all high powered pics are taken at about 375x magnification. after each test, i inspected the blade's edge and i took the high powered pic showing the worst area of the edge.
before i started the tests, each knife was able to easily push cut newspaper against the grain
first up was a spyderco endura 4 ZDP-189 FFG:
ZDP
after the test, ZDP wouldn't cut the newspaper either with or against the grain, but it still cut cardboard pretty easily.
next up was my spyderco para 2 with S30V.
S30V
after the test, S30V wouldn't cut newspaper either with or against the grain. S30V also wouldn't cut cardboard.
knife #3 was a spyderco 52100 mule.
52100
after the test, the 52100 wouldn't cut newspaper either with or against the grain, but it was able to cut cardboard pretty easily.
knife #4 was a buck vantage select large (420HC steel)
420HC
after the test, the 420HC wouldn't cut newspaper either with or against the grain, but it would still cut cardboard pretty easily.
p.s. out of the four knives tested so far (the 3 spyderco's were full flat grinds) the vantage select had a little less resistance while cutting.
it was probably the fact that the buck has a very deep hollow grind.
Благодарил (а): 1001 раз
Re: сравнение выкрашивания zpd-189 s30v 52100 420HC (eng)
:-( s30v как-то грустнее всех выглядит, а у меня ее больше всего
:D пора менять
Kart
Благодарил (а): 748 раз
Сообщение Kart »
Прикольно... Тапки правда, могли содержать разное количество песчинок в подошвах...
ljoint
Благодарил (а): 59 раз
Сообщение ljoint »
мула захотелось :)
chechen
Сообщение chechen »
Сразу видно что чувак очень любит Ньюбэлэнсы и Спайдерки. :smile:
__Z V I R__
ну дык бруклин. :smile:
щас там и спайдерок-то особо не купишь
или ньюбелансы не любит :)))
IRBIz
Сообщение IRBIz »
Хм..я только в суботу свои старые ECCO шинковал ::derisive:: Правда исользовал серейторное лезвия на лезермане чардже :) Хотел посмотреть как у ECCO сейчас ступинатор устроен .
WATBFB
vadel
Сообщение vadel »
хехе
бак-то прорулил
было бы интересно увидеть бак вантаж про, с той же s30v. Поскольку там у неё очень хорошая термичка. Как владелец такого, и есть с чем сравнивать, могу сказать что на баке вантаж-про с клеймом BOS-а сталь s30v ведёт себя много лучше, даже чем на спайдырках
JE SUIS TERRIL !!!
Ну парамиля 2 закалена на меньшую твёрдость чем тотже натив :)
__Z V I R__
бак-то прорулил
конечно прорулил. кто-нидуть когда-нибудь видел, чтобы кастрУльная нержа выкрашивалась? хе-хе.
данный тест интересен тем, кто не имея опыта реального поюза здпшки огульно рассуждает о её повышенной хрупкости.
Чкылчи
Сообщение Чкылчи »
вобщем то любой тест интересен, но я присоединюсь к Карту в мнении о том что в ношенной обуви абразивчик есть (песочек это одно, а если мелкий камушек?)
Ещё меня офигенно с толку сбивают выходящие на РК следы от крупного абразива ::acute:: это всем известные концентраторы напряжений. отличные аккуратные сколы по таким рискам получатся должны :wink: (а риски как раз к местам сколов и примыкают)
а у 52100 (наша ШХ) такие риски на РК не выходят, и повреждения у неё минимальные :)
ещё одно подтверждение того что затачивать перед тестами нужно тщательно, чтоб ни один не подкопался
Barmaley
Сообщение Barmaley »
а что это за горизонталльные полоски???...все никак не пойму...обоснование Чкылчи
считаю верным :)
big nik
Сообщение big nik »
ньюбеланс кул, был :smile:
Corsair
Сообщение Corsair »
Тапки какие то грустные получились. :-(
Интересно было бы узнать размер сколов? А то кратность х375 на моё воображение угнетающе действует :wink:
Виталий
Сообщение Виталий »
Последний раз редактировалось Виталий 01 авг 2019, 18:05, всего редактировалось 1 раз.
для чистоты эксперимента могли взять 3 вантажа и расписать результаты - вот это был бы кул... :)
deily писал(а):для чистоты эксперимента могли взять 3 вантажа и расписать результаты - вот это был бы кул... :)
Тогда и тапки нужны с одинаковым пробегом по одной и той же местности.
Demon-net
Сообщение Demon-net »
Именно...
Так признаёмся кто носит 3-и шт. за раз)
Hunter
Участник
Сообщение Hunter »
Чкылчи писал(а):затачивать перед тестами нужно тщательно, чтоб ни один не подкопался
Мало того, затачивать нужно на оптимальных абразивах. И никаких алмазов.
Именно...
или кто та пара инвалидов, которые носили зарезанные тапки в разной местности... :smile:
Вернуться в «Тесты»
