журнал Knives Illustrated: результаты тестов CATRA 6 сталей
- __Z V I R__
на блейдфоруме интересная тема
These were hollow-ground 0.125" test blades heat treated by Bob Dozier to Rc 60-61. The test is cutting against stacks of 5% silica cards with a 50 newton force applied throughout a 40mm cutting stroke at 50mm/sec.
Steel - Total cards cut
10V - 1044
S60V - 1030
S90V - 1014
3V - 682
S30V - 541
154CM - 468
here are the edge thickness at the top of the bevels
154CM-.008
S30V-.018
3V-.016
S60V-.013
S90V-.014
10V-.013
Сэл Глессер откаментил:
1. Spyderco does have a CATRA and we do extensive testing on all steels. We also test steels for foundries, Like Crucible and Carpenter. We tell others that since we are not an "accredited testing agency", it would not be proper for us to be used as an information source.
2. Any results that are published can be challenged by anyone for any reason. eg: their particular steel did not represent as they wanted.
3. We generally test at the optimal using hardness. We believe that CPM-S60V is not effective at RC61. I dropped an RC62 CPM-S60V blade on concrete and it literally cracked in half.
4. We had different results than those posted. Now what? I think you can see why Spyderco, Buck, Case, Leatherrman, etc. do not publish their results. (I believe there are fewer than 30 CATRA machines in use. They are quite expensive)
5. We learned after 10 years of testing that CATRA results are not the end all and be all of testing. "Real world" testing will sometimes yield different results than the CATRA for unforseen reasons.
6. We've always shared our findings with our customers as to our results. We just don't quote numbers.
10V - 1044
S60V - 1030
S90V - 1014
3V - 682
S30V - 541
154CM - 468
154CM-.008
S30V-.018
3V-.016
S60V-.013
S90V-.014
10V-.013
- cornel
Re: журнал Knives Illustrated: результаты тестов CATRA 6 сталей
Спасибо за интересный материал.
Было б интересно иметь некий показатель (даже если он будет интегральным) "потребительского качества" сталей, но описанный способ слишком однобокий, на мой взгляд.
Всё равно как если б степень нашей обучаемости (одно из достаточно важных качеств) выявляли простым взвешиванием.
А так - абсолютно верное направление - использовать механизм и комп для анализа, многократного повторения, усреднения и фиксации "индекса КАТРА"
Лишь бы на этом примитивизме все и не остановилось, слишком уж набили оскомины процессорные гиганты со своими "индексами производительности".
Код: Выделить всё
154CM-.008
Endura 4 Emerson Wave
- __Z V I R__
толщина кромки. т.е. нож с этой сталюкой был сведён наиболее тонко.
То есть между 30-кой и 154-й не такая уж и большая разница. Хотя по ощущения от реза этого не скажешь. Ну и термичка играет давлеко не последнюю роль. Скажем, та же 30-ка на 59 и 61 единицах - две совершенно разные стали. Но инфа полезная, спасибо огромное.
- vadel
термичка да... Bos рулит и бибикает. Я тут походу тестирую
S30V:
Бак Вантаж-Про
Бак 110 Аляска Гайд 8)
Лезерман Чардж ТТи
S30V:
Бак Вантаж-Про
Лезерман Чардж ТТи
JE SUIS TERRIL !!!
- das
vadel
по поводу литерман ти -
а вот и неудивительно я считаю
После просмотренного видео где увидел что вырезает лезвия лазером.
- он же выжигает мм на 3 в стороны нах, какой после этого тмо может быть?
- Сергей Сергеевич
Кроме разницы в ТМО очень много еще могла дать двукратная разница в толщине подводов - 154CM-.008, S30V-.018...Aleks писал(а):То есть между 30-кой и 154-й не такая уж и большая разница.
С этим поспорить сложно.
Перепроверка данных - это всегда хорошо.
Но, в данном случае, открытия не произошло, ибо вот эта табличка давно есть в даташитах Крусибл:
154СМ работает так только на приличной твердости, плюс Крусибл рекомендует заморозку в процессе ТО, а я сомневаюсь, что большинство это делает.
- __Z V I R__
конечно давно, но данные таки отличаются.
не особо сильно, что и не удивительно с учётом того, что данная диаграмка, судя по всему, подготовлена по результатам той же катры. вполне возможно что спай и делал её, исходя из слов спая.
???__Z V I R__ писал(а): вполне возможно что спай и делал её, исходя из слов спая.
И еще у меня вопрос по заточке, которая имеет большое значение для стойкости РК.
Единообразная для всех не позволит выявить полный потенциал сталей.
- __Z V I R__
Hunter писал(а):???__Z V I R__ писал(а): вполне возможно что спай и делал её, исходя из слов спая.
А, тогда в одном месте "спай" надо на Крусибл заменить, а то спай со своих же слов...
- __Z V I R__
если тонее, то фраза должна быть такой: "возможно что спай и делал её, исходя из слов сэла глессера."
__Z V I R__
отсыпь, - не могу понять смысл фразы
- __Z V I R__
(слова сэла не исходник для диаграмки, а источник инфы, исходя из которых сделан вывод)
спай делал тесты на катре для крусибла
об этом сказал сэл глессер
твоя диаграмма построена крусбилом на основании тестов
скорей всего на основании тестов проведённых спаем
тех тестов, о которых говорил сэл глессер
А, все, теперь прочувствовал фразу
Просто при таком построении она может быть воспринята иначе, если читать бегло
- __Z V I R__
да я попытался прочитать свою фразу по-другому (хотя это и тяжело) и понял в чём причина недоразумения.
кстати, на диаграмке нет с60в, а износостойкость цпм3в ниже чем у с30в. это к вопросу об отличии от тестов журнала
Нюанс в восприятии запятой, но это могут быть мои персональные "тараканы"__Z V I R__ писал(а):да я попытался прочитать свою фразу по-другому (хотя это и тяжело) и понял в чём причина недоразумения.
Скорее всего разгадка в ТМОа износостойкость цпм3в ниже чем у с30в. это к вопросу об отличии от тестов журнала
Если я правильно помню, то Алан писал об этих особенностях 3-ки.
- Alex ZZZ
HUNTER всё время правильно обращает внимание на ТМО, хотя большинство игнорирует это...
поддерживаю его...
надоело может всем - но 420я от BUCK это ведь с практической точки зрения ну просто превосходного качества клинок и за небольшие деньги ведь.
также, особенно применинительно к Б\У - ведь если как пишут некотрые форумчане на электро-точиле убрать кромку - то и вся ТМО уберётся..
но появление таких коэфициентов - хороший знак, ещё парочку, потом систему анализа и будет "азбука по выбору оптимальной стали"...
а то спорим тут и каждый со своими предпочтениями
даже нашли термин - СПОРНАЯ СТАЛЬ
поддерживаю его...
22 сообщения
