Подскажите, родной рассеиватель существует или нужно чужой подбирать?
• Utilizes a Nichia white GS LED with a life of 100,000 hours
• Constant brightness: 10 Lumens
• Uses one 1.5V AAA ( Alkaline, Ni-MH, Lithium ) battery, inexpensive and widely available
• 7.1cm (Length) x 1.4cm (Diameter)
• 21-hour working time ( 11-hour sun mode plus 10-hour moon mode)
• Made of durable aircraft-grade aluminium
• Durable Type III hard anodized finish
• 14-gram weight (excluding batteries)
• Waterproof to IPX-8 Standard
• Reliable twist switch
• Capable of standing up securely on a flat surface to serve as a candle
