ZebraLight SC30 CR123 Flashlight
$69.99
Вот тут продают
Вроде как обещают версию на АА питании )
Остается главный вопрос, почему этой модели нет на офф сайте? )
http://www.cpfmarketplace.com/mp/showth ... p?t=210712Main Features and Specifications
LED: Cree XLamp Cool White (color temperature 5700-6350 K)
Light Output:
High: 193 Lumens (0.9 hrs) or 105 Lumens (2 hrs)
Medium: 38 Lumens (12 hrs) or 21 Lumens (23 hrs)
Low: 4 Lumens (3.7 days) or 0.4 Lumens (21 days)
Light output are out the front values. Runtimes performed using a Panasonic CR123A lithium battery.
Battery: One CR123A lithium (batteries not included in the package)
Dimensions:
Diameter 22 mm (0.85 inch)
Height 67 mm (2.60 inch)
Weight: 30.5 gram (1.1 oz) without battery
Features
Electronic light touch switch with 200,000 cycle operating life
Smart user interface provides fast access to all light levels
Precision machined casing from premium grade Alcoa aluminum bar stock, light weight with superior structural strength
Proprietary heat sinking design bonds the LED metal core board directly to the uni-body aluminum casing, providing unblocked thermal paths to over 92% of the surface area.
Durable natural hard anodized finish (Type III Class I)
SCHOTT ultra clear lens with anti-reflection coatings on both sides
Can be used as a headlamp with the included headband
Bezel down clip
Waterproof to IPX8
Operation
From Off
Press and hold to cycle through Low, Medium and High, release to set
Click to High, click again quickly to cycle through Medium, Low and High
When On
Click to Off
Press and hold to cycle through Low, Medium and High, release to set Double click at any level to toggle between the two modes for that level
Accessories in the package
One black silicone holder with headband
"The current ETA for the SC30 is the end of January. Next up is the SC30w, a warm white version, in February"
