Фотогалерея Спайдерко
Благодарил (а): 6020 раз
Re: Фотогалерея Спайдерко
Благодарил (а): 935 раз
:-D rt24
DistortioN
Сообщение DistortioN »
redflag
Сообщение redflag »
Красавцы. Все и у всех. :)
Благодарил (а): 3689 раз
DistortioN, самый нижний rt24
DistortioN
Нижний - даа! Привез его из самого Golden, Colorado, USA, Earth. :)
Легкий, стильный, легендарный, резучий. :)
old large C48 Tim Wegner
вах ::jctong::
Urs
Благодарил (а): 331 раз
Сообщение Urs »
Так это же Blade-Tech Pro-Hunter. Один-в-один. Как бы и фамилия на клинке на это намекает.
Urs писал(а): Так это же Blade-Tech Pro-Hunte
:D
I designed the Spyderco/Wegner Clipit to be a multi-roled knife which will accomplish all that a back country hunter would require of it in the field while working on an elk sized animal, and still keep its' edge. Keep in mind that any knife will dull if it is used to cut through the dirty hair of a game animal.
The design is what I would call a modified Loveless semi-skinner. The original Spyderco prototype which appeared in pre-production photos had a tip that was too wide for intricate cutting, and the belly was too acute and would have been detrimental to its' intended role as a utility hunter. Spyderco made the changes at my request. The only differecne between the custom version and the production version are the point, the semi-skinner hump, and the length. The point is 1/8" lower on the production knife and the semi-skinner hump is slightly less pronounced. The length at 3 5/8" is 1/8" shorter than the custom. I kept these slight variations in the production knife because they make it an even better knife for all around utility without sacrificing any of its' capabilities as a hunter. https://www.bladeforums.com/threads/mes ... fe.120870/
а вот обзор камрада krizis13 viewtopic.php?t=42391
Urs писал(а): Так это же Blade-Tech Pro-Hunter. ,
такой да не такой, про хантер есть
а вот спай бы заполучить :-)
Был еще Спаевский Оцелот от Вегнера , тоже классный , с лапками :) ,когда то давно в руках держал, почему не купил ()(! , формфактор аналогичный .
stilet писал(а): Спаевский Оцелот от Вегнера , тоже классный , с лапками
на серийке бэклок
а на прототипе компрешен :)
https://www.spyderco.com/forumII/viewtopic.php?t=68194
Prototypes. The one marked Spyderco Prototype is "official" and part of batch of them which were sold. I believe there are about 30 of them. The topmost one is, shall we say, unofficial and, as far as I know, one of a kind. Both are compression locks with nested liners and BG42 blades. IIRC, technically they're not Ocelots, they're Trak'rs, since that was the original name for the model.https://www.spyderco.com/forumII/viewtopic.php?t=39617
Ну чем не Оцелот?
Ну если смотреть в целом , то Спайдерки почти все "оцелоты" внешне , но с лапками один :-D .
pr13s7
Благодарил (а): 59 раз
Сообщение pr13s7 »
Благодарил (а): 2655 раз
переточений типу?
Благодарил (а): 554 раза
pr13s7
Сообщение pr13s7 »
pr13s7
Сообщение pr13s7 »
