Итак нож сделан в Китае, из дешевой стали, замка никакого не имеет - одним словом безделушка... Но зато самый маленький SpydercoThe Bug, not much larger than a bee, is our latest addition. Last year Spyderco started offering SLIPITS which are non-locking slip-joint knives. They have no locking mechanism holding the blade open, relying instead on resistant pressure at the pivot area when the blade is extended and being used. Bugs are part of the SLIPIT group.
The flat ground blade is 3Cr13MoV stainless steel available with a PlainEdge. The Bug's handle offers a flat surface for a small amount of engraving or embellishment and can be customized for use as jewelry or a gift item. Positioned on the end of the handle is a lanyard hole large enough to thread with a chain and be worn around the neck or slipped onto a key chain. The Bug is the smallest folder in our lineup.
Характеристики с сайта производителя:
Фото:length overall 2 7/8" (73mm)
length closed 1 5/8" (41 mm)
hole diameter 3/16" (5 mm)
blade length 1 5/16" (33mm)
cutting edge 1 1/8" (29mm)
blade thickness 1/16" (1.75mm)
blade steel 3Cr13MoV
weight .4oz (12g)
handle material Stainless Steel
В комплекте маааленькая коробочка и сам нож в пакетике. Цепочка и прочие аксессуары приобретаются отдельно
