The new JETBeam BK135A is the smallest AA flashlight in the JETBeam line. It features JETBeam's I.B.S. user interface, which allows the user to set any brightness level from 5-135 lumen on each of the 3 modes.
Also features 15 different strobe speeds, SOS, and other beacons to choose from. Small enough to fit on a keychain, but bright enough to light up 1/2 a football field!
This latest edition comes in a limited camo finish. JETBeam BK135A flashlight features the same I.B.S. user programmable UI found in popular JET-I PRO and JET-III PRO flashlights.
BK135A IS compact, rich in features. Utilizes a Cree XP-G R4 LED with max 135 lumen output.
Features:
LED: Cree XP-G R4 bin
Max output: 135 lumens
Reflector: Aluminum OP reflector
Lens: Coated mineral glass
Finish: HA III Military grade hard anodized
Battery Type: one AA battery
Waterproof: Meets IPX8 waterproof standards
Specifications:
Features JETBeam's I.B.S. user programmable circuit and allows the three user-defined modes to be customized to any brightness level.
Stainless steel rings to protect circuit and thread
Reverse polarity protection function
Tail stand feature
Size: diameter 17mm, length 90mm
Weight: 27g (not including battery)
Runtime and Output:
One AA battery
Max output: 135 lumens, 65 mins
Min output: 2 lumens, 50 hours
Packaging: Aluminum Gift Tin
Цена 59$
