Новая Zebra H31
Новая Zebra H31
Zebra H31 Headlamp CR123 220Lm
LED: Cree XP-G Cool White (color temperature 6100-6500 K)
User Selectable Modes: 3 (High, Medium and Low). Each mode can be configured to one of the two sub-levels.
Light Output:
- High: H1 220 Lm (0.9 hrs) or H2 120 Lm (2 hrs)
- Medium: M1 43 Lm (12 hrs) or M2 24 Lm (23 hrs)
- Low: L1 5 Lm (3.7 days) or L2 0.5 Lm (21 days)
Light output are out the front (OTF) values. Runtime tests are done using Panasonic CR123A lithium batteries. Runtimes are usually much shorter with rechargeable RCR123 (16340) batteries, especially with protected 16340s that have higher discharge cut off voltage.
Battery: One CR123A lithium primary or RCR123 Li-ion rechargeable. Batteries are not included in the package.
Beam Type:
- 76° spill beam spread
- 8.6° (3 feet at 20 feet) hot spot
Dimensions: 23 mm х 65 mm
Weight: 27.6 gram with clip, without battery or headband
Features:
Electronic soft-touch switch, with a 200,000 cycle operating life
Smart user interface provides fast and easy access to all brightness levels
Precision machined casing from premium grade Alcoa aluminum bar stock
Proprietary heat sinking design bonds the LED metal core board directly to the uni-body aluminum casing, providing unblocked thermal paths to over 92% of the surface area.
Durable natural hard anodized finish (Type III Class I)
SCHOTT ultra clear lens with anti-reflection coatings on both sides
Bezel down clip (pre-installed)
Can be used as a headlamp with the included headband (clip can remain installed when the light is on the headband)
Orange peel textured reflector
Anti-roll and tail-stand capable
Glow In The Dark (GITD) silicone ring near the tail cap
Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations
Waterproof to IPX8
Light Output:
Beam Type:
Features:
Waterproof to IPX8
- Aleksandr Afonchenko
- Afonchenko Knives
Re: Новая Zebra H31
Ну ребята вобще молодцы
Кнопку с диодом поменяли и вот те на, новый фонарик.
- Торъ
Re: Новая Zebra H31
А что значит Н1 и Н2 и соответственно М1 и М2 и т.д. ?
Т.е. будет возможно выбирать В КАЖДОМ из режимов - High, Medium, Low два типа на выбор? Прикольно... И сколько ж это счастье будет коштуваты? А то зебры ценой не очень радуют.
Последний раз редактировалось Торъ 20 фев 2010, 16:44, всего редактировалось 1 раз.
Re: Новая Zebra H31
Вот как вариант, еслиб они сделали, так, нужен налобник взял перекрутил модули диода и кнопки и вот те на, налобник
нужен обычный фонарик, перекрутил обратно
Ну просто как идея.
Ну просто как идея.
- Santos_DS
Re: Новая Zebra H31
Честно говоря, в зебре нафиг надо такие слабые-сильные режимы. Если б еще в обычном фонаре, то да, зер гуд, но не в зебре, она и в самом слабом режиме (Н30) не очень чтоб, а еще слабее, то ваще будет овно редкостное... :(
Re: Новая Zebra H31
Santos_DS
Все относительно.
В Н30, например, средний режим слабоват, а минимальный - слишком яркий, ночью спросонья слепит.
Все относительно.
Re: Новая Zebra H31
Именно такТоръ писал(а):Т.е. будет возможно выбирать В КАЖДОМ из режимов - High, Medium, Low два типа на выбор?.
А по ссылке сходить лениво?И сколько ж это счастье будет коштуваты?
$59.00
Цены у Зебры весьма и весьма доступные
Кто не верит - может посмотереть на цену Шурфаер Минимус.
- Берс
Re: Новая Zebra H31
То ли они что-то напутали,то ли новый диод при тех же люменах меньше потребляет:
В Зебре Н30:
*Medium 20 Lumens (21 hours)
*Low 4 Lumens (3.7 days)
А в Н31:
M2 24 Lm (23 hrs)
L1 5 Lm (3.7 days)
Мне кажется,такая мощща при той же батарейке - не годится.Слишком быстро будет садиться.Для мощщи я когда-нить НР10 куплю
А вот что кнопку утопили - это гут (только поздно
В Зебре Н30:
А в Н31:
M2 24 Lm (23 hrs)
L1 5 Lm (3.7 days)
Re: Новая Zebra H31
всё правильно, XP-G более эффективен.Берс писал(а):То ли они что-то напутали,то ли новый диод при тех же люменах меньше потребляет...
впрочем как всегда - новое поколение имеет более высокий КПД и к-во люмен с ампера.
- Берс
Re: Новая Zebra H31
Это хорошо,прогресс радует.Теоретически,экстраполируя такие данные,через сколько-то лет у нас будет,если можно так выразиться - "дофига из нифига"soe писал(а):XP-G более эффективен
Re: Новая Zebra H31
"теоретический предел для светодиодов учёные определили как 320 люмен на ватт, а реально достижимый параметр на ближайшие годы — 213"
сейчас у XP-G 132 люмен/ватт.
т.е. теоретически - 132*3=396 bulb-lumen c диода!
мало того, максимально допустимый ток 1,5А а не 1.0А как у XR-E (Q5, R2).
а на сегодня КПД светодиода менее 50%, меньше чем у люминисцентных ламп...
- Торъ
Re: Новая Zebra H31
Вопрос, когда такое на АА будет?
- Kren
Re: Новая Zebra H31
какое ж старье?Codename 47 писал(а):Все выходит выходит, куча анонсов а в инет магазинах по прежнему старье
Были бы и остальные новинки..но азия празднует свой новый год почти месяц
14 сообщений
