Анонсирован уже и на официальном сайте:
Cree XP-G LED (R5) with lifespan of 50,000 hours
• Three levels of brightness, Mid (110 Lumens, 3Hrs ) -> Low (7 Lumens, 64Hrs ) -> High (216 Lumens, 1Hrs )
• Max beam length: 96 meters
• Digitally regulated output - maintains constant brightness
• Powered by one 3V CR123A lithium batteries
• 73mm (Length) x 19mm (Diameter)
• Made of Titanium
• 38-gram weight (excluding batteries)
• Waterproof to IPX-8 Standard
• Toughened ultra-clear glass lens with anti-reflective coating
• Reliable twist switch (Patented)
• Capable of standing up securely on a flat surface to serve as a candle
• Included accessories: lanyard, two spare o-rings, body clip
разрядный график!!! :
http://www.fenixlight.com/viewnproduct.asp?id=62
P.S. Цена пока неизвестна, но точно намного дешевле чем в --
