http://www.fenixtactical.com/fenix-pd20.html
светодиод XP-E R2
190 лм, клипса...
Features of Fenix PD20 2010:
• Cree XP-E LED (R2) with lifespan of 50,000 hours
• 2 modes with 6 types of output:
Turbo Mode: 190 lumens (1hrs) -> Strobe
General Mode: 9 lumens (35hrs) - > 48 lumens (7hrs) -> 96 lumens (2.8hrs) - > SOS
• Max beam length - 135 meters
• Digitally regulated output - maintains constant brightness
• Uses one 3V CR123A battery (Lithium)
• 78.5mm (Length) x 21.5mm (Diameter)
• Made of durable T6 aircraft-grade aluminum
• Premium Type III hard-anodized anti-abrasive finish
• 39-gram weight (excluding the battery)
• Waterproof to IPX-8 Standard
• Toughened ultra-clear glass lens with anti-reflective coating
• Push-button tail cap switch
• Capable of standing up securely on a flat surface to serve as a candle
• Included accessories: lanyard, two spare o-rings, body clip,and a rubber switch boot
срок поставки - конец ноября
