21 января оружейный мир будет вспоминать великого конструктора-оружейщика Джона Мозеса Браунинга.
Это день его рождения.
А 15 января этого года компания Browning представила свою очередную новинку - модель Maxus II
Первый Maxus на рынке довольно долгое время, отзывов много, давайте посмотрим на Maxus II
Browning introduces the new Maxus II, the most reliable, best handling, and smoothest operating autoloading shotgun on the market.
Beginning with the tried and true Power Drive Gas System and reliable Maxus action, the new Maxus II features a number of modern advances. Highlighting these features is the all-new stock design that targets both a customized fit as well as a smoother shooting experience. The straight heel buttstock allows for customizing the length of pull by either adding spacers or trimming the stock down.
The 1-1/2" thick Inflex recoil pad features directional deflection and is coupled with the new SoftFlex Cheekpad, both of which are designed to soften recoil against your shoulder and face. Rubber overmolded panels on the pistol grip and forearm improve grip and feel.
Enhanced operational features include an enlarged trigger guard that is ramped for fast loading, oversized bolt handle and release that are easier to use and a traditional threaded magazine cap.
The raises rib sight picture and flat point of impact puts shooters on target faster and more consistently.
Features:
New receiver styling
New SoftFlex™ Cheek Pad increases shooting comfort
New oversize bolt release and bolt handle
New composite stock can be trimmed and is shim adjustable for cast, drop and length of pull
New rubber overmolding on stock and forearm add grip in all conditions
New trigger guard is ramped for easier loading
Nickel Teflon™ Coating on the bolt, bolt slide, shell carrier, bolt release and bolt
Lightweight magazine tube reduces weight
Chrome chamber and bore increase durability and corrosion resistance
HiViz Tri-Comp fiber-optic front sight and ivory mid-bead
ABS hard case included
Three Invector-Plus choke tubes included (F, M, IC)
For more information on Browning products, please visit browning.com
SOFTFLEX™ CHEEKPAD
The new SoftFlex cheekpad uses the same technology as our
REACTAR G3 shoulder pad to increase shooting comfort
INFLEX RECOIL PAD
The 1-1/2" thick Inflex recoil pad uses directional deflection to send the comb down and away from the face,
reducing felt recoil for greater shooting comfort and allowing faster, more accurate follow-up shots
ENHANCED CONTROLS
An oversized bolt handle and enlarged bolt release offer positive operation in all conditions
SCREW-ON MAGAZINE CAP
The new forearm features a traditional, screw-on magazine cap
NEW STYLING
A more adjustable stock, screw-on magazine cap, enhanced grip, an enhanced trigger guard and improved
shooting comfort are a few of the new features of the Maxus II and contribute to the sleek, revised styling
RUBBER OVERMOLDING
The Maxus II features a trim forearm and close radius pistol grip with rubber
overmolding panels to maximize control and grip
RAMPED TRIGGER GUARD
New trigger guard design is ramped to make loading shells into the magazine easier
