Новинка: Solarforce P1 - "почти" Surefire :)
Eagle
Re: Новинка: Solarforce P1 - "почти" Surefire :)
Сообщение Eagle »
Specifications and Features:
Consists of head, battery tube and tail-cap switch (drop-in LED modules are not included), which are replaceable and compatible with the Solarforce accessories
Mainly constructed of GFRP and aluminum alloy
Colours available: black, yellow, brown and green
Uses two CR123A or 16340, or one 18650 battery by default
Tail-cap standard (forward) click switch (momentary on with a slight press, constant on after a click), able to withstand 3A current.
Water-proof design
Size (head diameter x length): 34 x 136mm
Weight: 68g (excluding drop-in modules and batteries)
Users may purchase the corresponding Solarforce accessories based on their preference and needs, to use with the P1:
High-performance LED Drop-in Module, with different beam colour, power output, output modes, input voltage, beam pattern, etc:
LC-1
Module consists of a CREE XLamp XR-E LED and an aluminum reflector (light orange-peel-textured reflective coating)
Outer diameter of reflector: 26.5mm
Maximum output at 250 lumens #
Model available (Luminous flux level, mode available, input voltage):
LC-1 (Q4, single mode, 3V-18V)
LC-1 (Q4m, 5 modes, 3.7V-8.4V)
Compatible with L2, L2m, L2T, L2P, L2T (Special Edition), Gladiator, P1
(*5 modes = 100% - 40% - 10% - Flashing - SOS - Repeat (with memory function) )
LC-XPG
Module consists of a CREE XLamp XP-G LED and an aluminum reflector (light orange-peel-textured reflective coating)
Single mode output
Maximum output at 300 lumens#
LC-XPG (R5, single mode, 0.8V-4.2V)
LC-XPG (R5, single mode, 3V-18V)
LC-XPG (R5, 3 modes, 0.8V-4.2V)
LC-XPG (R5, 5 modes, 4.2V-8.4V)
(*3 modes = 100% - 40% - 10%; 5 modes = 100% - 40% - 10% - Flashing - SOS - Repeat (with memory function) )
LC-XML
Module consists of a CREE XLamp XM-L (T6-binned) LED and an aluminum reflector Outer diameter of reflector: 26.5mm
Single and five modes output
Maximum output at 500 lumens#
LC-XML (T6, Single Mode, 3.7V)
LC-XML (T6, 3 Modes, 3.7V)
LC-XML (T6, 3 Modes, 3.7V - 8.4V)
LC-XML (T6, 5 Modes, 3.7V)
LC-XML (T6, 5 Modes, 3.7V - 8.4V)
(*3 modes = 100% - 40% - 10%;5 modes = 100% - 40% - 10% - Flashing - SOS - Repeat (with memory function) )
LC-Colour
Module consists of a CREE LED and an aluminum reflector (orange-peel alike reflective coating)
LC-1 (Yellow, single mode, 3V - 18V) (light tint is close to that of incandescent bulb)
LC-1 (Red, single mode, 3V - 18V)
LC-1 (Green, single mode, 3V - 18V)
LC-1 (Blue, single mode, 3V - 18V)
LC-1 (Red, 5 modes, 3.7V - 8.4V)
LC-1 (Green, 5 modes, 3.7V - 8.4V)
LC-1 (Blue, 5 modes, 3.7V - 8.4V)
LC-IR
Module consists of an IR LED and an aluminum reflector (mirror-like reflective coating)
Wavelength: 850nm
Input voltage: 3.7 - 8.4V
LC-UV
Module consists of an UV LED and an aluminum reflector (mirror-like reflective coating)
Wavelength: 380 - 450nm
Input voltage: 3 - 6V
Compatible with L2, L2m, L2T, L2P , L2T (Special Edition), Gladiator, P1
IH-1
Consists of a xenon bulb and an aluminum reflector (light orange-peel-textured reflective coating)
Wide range of different input voltages available: 3.7V, 6V, 7.4V, 9V, 12V, 14V
Nylon Holster, delicate and durable: FH-1, FH-6
Battery Charger: SF-16 (16340), SF-18c (18650)
Batteries: CR123A (primary lithium battery), S16340-P, RCR123A, S18650-P, S18650P(V2) (rechargeable li-ion battery).
С уважением,
Александр.
SML
Сообщение SML »
Дайте желтый :cool:
ALTERMANN
Сообщение ALTERMANN »
почти это как настоящий только не очень :-D
Aleksandr Afonchenko
Afonchenko Knives
Afonchenko Knives
Прикольно, вот только где купит и за сколько.
ALTERMANN
С чего именно шурфаейр он больше на inforce похож тоже пластик, тоже пропилы в корпусе, только модули от ШФ.
а так название можно дать M6 Djigurdian :-D
MIKAlex
Сообщение MIKAlex »
Не впечатляет ...
ТТХ дают как на обычные алюминиевые фонари ...,
а теперь подумайте что там с теплоотводом ...
и надолго ли даже бюджетные и легкодоступные дропины ...
Паха
Сообщение Паха »
А вот интересно, эти бОшки (рефлектор-диод-драйвер) под 26мм, значит теоретически подойдут под ультрафаеры моделей 501-503. Но в обычных китайских имхо хреновые драйвера, а где бы такие, нормальные, прикупить?
