От КЗ в первую очередь
Про кнопку - ее там НЕТ, судя по описанию на DX - там twist switch - т.е. кнопку исполняет процесс механического затягивания резьбы - замыкается контакт и не надо мучаться с мегатолстыми контактами кнопки, кнопкой с нулевым сопротивлением и т.п. Oveready делают такие кнопки (zero-resistance kit вроде). Кстати идею у них скомуниздили dereelight, только оно им не сильно помогает, читай про контроль качества и инжиниринг
Кстатте:
This flashlight feels very solid - and is definitely very bright. I am using the 18650 Trustfire protected batteries, and they work great. I am wondering if several of you had similar experiences as myself?
I used the flashlight to see how bright it was, but the first time I actually used it, it died in 3 - 4 minutes. I thought the batteries were bad, so I used a different set of trustfires, but no good. Then I took out the bulb to look at it, and sure enough, it was blown!!! Should I just purchase additional bulbs (I think someone already suggested it) or replace it with the P4 cree (less light, longer run time). DX however has excellent customer service, and they are replacing my bulb. Thanks!
ezpc09 Thursday, June 05, 2008 10:03 PM Reply
I have one for a while now and no it did not do that. I've been running it for several hours. What I did though is
I cleaned the bulb first with rubbing alcohol to get rid of potential oils left from installing the bulb. Mine runs great, I like to run a nice powerful cannie with all my other leds.
Исходя из этого:
а) проверить что лампа целая
б) протереть ее
Напоминаем: эти лампочки нельзя держать руками (кабум от жира), только латексные перчатки.
