"Олдтаймеры" и дух старины
BEST Slipjoint! @Blade_Show West - Luke @SwensonKnives tops the field.
Stockman splitback whittler.
CPM154 blades
Integral 416 milled frames / bolsters
Sambar stag scales
Tech Tool 1 Titan
Let us take you to the Greek mythology with the new Boker Plus Celos. As the son of the Titan Pallas, Zelos embodied the god of eager striving in Greek mythology. And the extremely handy Boker Plus Celos also finds its mythical destiny for the knife Olympus in the pursuit of perfection.
The compact slipjoint pocket knife is the perfect companion for everyday use and masters all cutting tasks effortlessly despite its small size. The blade is opened with a nail nick on both sides. The operating safety of the modern pocket knife is further enhanced by a 90-degree locking mechanism when opening and closing the blade. Two models are provided with a flat-ground 440C blade which has a fine satin finish. The textured handle scales are made of black G10 or Natural Jade G10, the semi-transparent original variant of the resistant composite material. In the extraordinary high-end version, the pocket knife is equipped with titanium handle scales and a flat-ground blade made of M390. The powder-metallurgical high-performance steel from Böhler convinces with the highest wear resistance and thus even tempts the gods. Strictly limited to 500 pieces worldwide.
GeorgCH писал(а): 18 окт 2021, 20:01 Greek mythology with the new Boker Plus Celos.
Ножі цікаві, в тренді.
Але все ж не кожен сліпджойнт є олдтаймером.
Thorwald писал(а): 18 окт 2021, 20:04 Але все ж не кожен сліпджойнт є олдтаймером.
зато есть в титане и М390.
Благодарил (а): 5669 раз
GeorgCH писал(а): 18 окт 2021, 20:14 зато есть в титане и М390.
Но не олдтаймеры ::hi:::
Ramok, соглашусь, новоделы не считаются :)
Lazyinventor писал(а): 24 янв 2013, 00:23 найти в наше время истинный «олдтаймер» можно наверное только купив оригинал. И именно старый. Нет! Очень старый.
Сколько есть real олдтаймер-в?
GeorgCH, у меня или в целом?
GeorgCH писал(а): 18 окт 2021, 21:12 Сколько есть real олдтаймер-в?
Один :smile:
https://www.theoldtimer.com/
Ramok писал(а): 18 окт 2021, 21:25 у меня или в целом?
всех наверно касается, под видом подлинников «олдтаймер-в" нередко предлагаются фальшивки, копии и новоделы.
Old Timer Knives были линейкой ножей, производимой Imperial Schrade Corporation.
Начинавшееся, как Schrade Cutlery в 1904 году, Old Timers вобрал в себя все традиции и дух первооткрывателей Америки. К сожалению, компания закрылась в 2004 году.
Сейчас продолжается производство эти ножей, но... это уже не то - часть делается в Китае, часть в США...
Текстовая ссылка на видео - https://youtu.be/1CH_bReYj_8
SCHRADE USA OLD TIMER 8OT Senior Stockman. Produced from 1959 to 2004. Nickle silver bolsters and shield, brass pins and liners. 1095 carbon steel blades, clip point main, sheepfoot and spey secondary blades. Brown sawcut delrin handles.
Благодарил (а): 6045 раз
Отримуємо “парадокс” :D
Як тільки на ножі з'являється напис “олдтаймер” - це “новодєл”.
Бо тру олдаймери були “сучасними” ножами (це якщо продовжити логіку попередніх постів)
надо разделять понятия: антиквариа́т (лат. antiquus «старый») и "олдтаймер" :smile:
В Украине антиквариатом, по мнению многих обывателей и мелких участников рынка, считается предмет, которому более 50 лет. :-D
Благодарил (а): 2524 раза
А как на самом деле?
Моё понимание - это ножи, сделанные из материалов и по дизайнам ножей, которые выпускались в конце 19 (когда о шраде никто не знал), начале 20 века. Никаких винтов, титана и М390. Понятие пошло из США. А это значит, что это ножи, ходившие в то время там (Шефилд и Золинген в т.ч). Но это моё виденье. Никому не навязываю.
Ramok писал(а): 18 окт 2021, 22:38 Понятие пошло из США.
Я у Рика спрошу
GeorgCH, ответ здесь напишите.
O.Phesun
Благодарил (а): 205 раз
Сообщение O.Phesun »
такий гарний ножик і в таких страшких ножнах..
О. О. Phesun ::hi:::
Ramok писал(а): 18 окт 2021, 22:38 Моё понимание - это ножи, сделанные из материалов и по дизайнам ножей, которые выпускались в конце 19 (когда о шраде никто не знал), начале 20 века. Никаких винтов, титана и М390. Понятие пошло из США. А это значит, что это ножи, ходившие в то время там (Шефилд и Золинген в т.ч). Но это моё виденье. Никому не навязываю.
згоден з подібним визначенням. хоча по матеріалам можна розширити, але в традиційних і максимально наближених патернах.
для мене "олдтаймер" - це більше про класичні патерни
GeorgCH писал(а): 16 окт 2021, 17:33 В Украине антиквариатом, по мнению многих обывателей и мелких участников рынка, считается предмет, которому более 50 лет.
Это по закону. Вещь, которая старше 50-ти лет, при вывозе за пределы Украины, считается предметом старины, и требует разрешения на вывоз. При ввозе же вещи старше 50-ти лет подлежат обязательному декларированию.
Explorer
Благодарил (а): 855 раз
Сообщение Explorer »
Капєц, я тещу без дозволів вивозив :? Контрабанда виходить...
Благодарил (а): 2467 раз
А как тогда декларировали?
Explorer писал(а): 19 окт 2021, 16:56 Капєц, я тещу без дозволів вивозив Контрабанда виходить...
Якщо живу, то ні cvb34 А якщо не живу, то звісно контрабанда :-D
O.Phesun
Дюк писал(а): 20 окт 2021, 08:23 то звісно контрабанда
контрабанда шкіри?
