PUBLIC SERVICE Announcement
Everything and anything can chip, even Cruwear.
If you misuse your knives, they can chip or deform so badly it is like a chip.
You mitigate this in two ways.
1. Stop misusing your knife, it's a cutting tool not a cold chisel.
2. One can Increase the edge angle so that it doesn't perform as well with cutting but will be better suited for shenanigans. Durability starts at 20dps. The Factory edges are at ~17dps. Everything is a trade off. Some folks probably need 30dps. Others can work with a 12dps depending on the end user so "git gud"
Thin geometry cuts but is more delicate yet thicker geometry is more durable but doesn't cut as good or as long. Its pretty straightforward, tune the edge geometry to YOUR ability/preference/uses.(C)
