Новинки фонариков в инет магазинах
Aleksandr Afonchenko
Afonchenko Knives
Afonchenko Knives
Re: Новинки фонариков в инет магазинах
Afonchenko Knives
Afonchenko Knives
Новый ДжетБим RRT 0
http://blackforce.stores.yahoo.net/rrt0.html
http://www.jetbeam.com.cn/links/pro/rrt0.aspx Ссылка на оффсайт
Model: RRT-0 (R2)
Specially designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and General Outdoors
The Rapid Response Control Ring allows the user to easily select different brightness levels
Choice of five brightness levels
New Ultra Low Mode
Stainless steel rapid response control ring, makes the RRT-0 very reliable and durable
Stainless steel bezel protect the head from drops and impacts
Stainless steel crenulated bezel can be used as a glass breaker or defensive tool
CREE R2 LED
Input voltage for RRT-0 is 0.8-4.2V
Max output of 240 lumen with an effective range of 200 meters
New hybrid reflector is specifically designed for the CREE R2 LED, which allows for better beam quality, efficiency and throw capability
Newly designed highly efficient broad voltage drive circuit
Compatible with both CR123 and RCR123 rechargeable Li-ion batteries
Floating positive end, designed for better contact
Built-in intelligent Li-ion rechargeable battery protection circuit
The RRT-0 is able to tail stand
Meets impact-resistant accords with US MIL-STD-810F and IPX 8 standard waterproof compliance
Dimensions: Head/Tail Diameter 25.4mm, Tube Diameter 20.5mm, Total Length 97mm
Weight: 86g
Output & Runtime: Using CR123 Battery or 14500 Li-ion
High Mode 240 Lumens, 45 min
Daily Mode 50 Lumens, 7.5 hours
Mid Mode 25 Lumens, 12 hours
Low Mode 10 Lumens, 20 hours
Lower Low Mode 1 Lumen, 100 hours
Using AA Battery
High Mode 180 Lumens, 45 min
Daily Mode 50 Lumens, 5 hours
Mid Mode 25 Lumens, 10 hours
Low Mode 10 Lumens, 15 hours
Lower Low Mode 1 Lumen, 80 hours
Что думаете коллеги?
Hunter
Участник
Сообщение Hunter »
Codename 47
Похоже, сбылась мечта многих - фонарь, который работает и от АА/14500, и от CR/RCR123
soe
Сообщение soe »
Codename 47
1. я сделал удобочитаемым, не против?
2. ну живьём я так понимаю его нету пока...
3. непонятно что с КПД драйвера, видимо издержки универсальности питания...
(Low Mode 10 Lumens, 20 hours, а у Fenix PD20 - 9 Lumens, 35 hours!)
4. клипса ещё у него зачётная, переставляемая.
5. луч наверное узкий, как обычно?
inakey
Сообщение inakey »
нда - для щастя не хватает зубьев на голове + возможности надеть на голову диффузор да регулируемого угла рассеивания. хотя насчет диффузора - не уверен, может какой и подойдет.
Hunter
мечта, она аки горизонт - ты к ей, она от тебя. и все витиеватей становится :-D
soe
если последняя фотка с оффсайта не симуляция - то таки да, луч зело узкий. так оно и понятно, ведь "designed for Military, Law Enforcement, Self-defense, Hunting, Search & Rescue and General Outdoors"
Afonchenko Knives
Afonchenko Knives
soe писал(а):1. я сделал удобочитаемым, не против?
Конечно я не против, так даже лучше rt24 но мне кажется цена в 100 уе без адаптора (с адаптором под батарейку) он стоит 110 вроде как это слишком дорого.
soe
Кстати, что думаете про эту модель, стоит она тех денег что за нее просят?
Donkey
Сообщение Donkey »
Мегаторч написал что цена будет 3500 руб.
http://talks.guns.ru/forummisc/mod_acti ... Num=001273
Наверное эта модель интересна как небольшой фонарик с кольцом режимов и под разные элементы питания.
Но если это будет уменьшенная копия Раптора-2 с такой же дальнобойностью, то точно своих денег не стоит, потому как 110 баксов стоит раптор-2
Afonchenko Knives
Afonchenko Knives
Интересная модель должна интересно стоить ) а не 120 уе я так прикинул что 3500 рублями на наши деньги это около 1000 грн, это где то 970 грн а это в долларах поряка 115 - 120 в зависимости от игры курса рубля и бакса, так что уже не совсем приятная цена для малыша. :-(
Donkey
Сообщение Donkey »
Codename 47 писал(а):Интересная модель должна интересно стоить ) а не 120 уе я так прикинул что 3500 рублями на наши деньги это около 1000 грн, это где то 970 грн а это в долларах поряка 115 - 120 в зависимости от игры курса рубля и бакса, так что уже не совсем приятная цена для малыша. :-(
Я тоже правда не понимаю, почему Раптор-2 который стоит 110$ у Мегаторча стоит 4600 при этом Раптор-0 который тоже идет по цене 110$ - уже 3500... Т.е. мне так думается что цена все же у Раптор-0 не 100 баксов, гдето 70-80, просто так как модель новая, то и цена ажиотажная. У Мегаторча наценка +1000 руб
Hunter
Участник
Сообщение Hunter »
На Лайтхаунде появились корпуса C-head под элементы питания формата АА (14500):
FiveMega C Head 1xAA
FiveMega C Head 2xAA
FiveMega C Head 3xAA
Hunter
Участник
Сообщение Hunter »
Donkey
Сообщение Donkey »
ну не такая существенная разница, на 4севенс они по 39$
Hunter
Участник
Сообщение Hunter »
Donkey
Подразумевалась не разница, а цена как таковая :D
Плюс с 4севенс мы заказы редко делаем, а с КВ - довольно регулярно.
Hunter
Участник
Сообщение Hunter »
А вот и дизайнерские вещи появились:
ICONlight ICON
Это радует :)
Торъ
Сообщение Торъ »
Этот 4Sevens Quark MiNi AA на новом диоде CREE XP-G R5?
http://www.knifeworks.com/4sevensquarkminiaa.aspx
Почему новый диод дает High: 90 OTF lumens, 1.3 hours
а Fenix LD10 на Cree Premium (Q5) дает 120 lumens (1.5hrs) ?
Hunter
Участник
Сообщение Hunter »
Торъ писал(а):Этот 4Sevens Quark MiNi AA на новом диоде CREE XP-G R5?
Я выделил один из ключевых моментов :)
Hunter
Участник
Сообщение Hunter »
Торъ писал(а):Hunter - и? просветите чайников плиз
OTF (out the front) lumens = torch lumens
http://knifeclub.com.ua/forum/viewtopic.php?f=93&t=4843
serezha171
Сообщение serezha171 »
Торъ писал(а): Почему новый диод дает High: 90 OTF lumens, 1.3 hours
Есть еще 1 причина. 1.3 часа для Quark Mini заявлено от обычной, щелочной батарейки. От NiMh Eneloop - 2 часа, от NiMh 2650-2700 - будут все 2.5 часа. А это немало!
SML
Сообщение SML »
NovaTac Classic, Black Aluminum Body, LED
http://www.lighthound.com/NovaTac-Class ... _3415.html
Specifications
* Overall Length (inches):6.00
* Material:Aerospace Aluminum, Type II Hard Anodized
* Finish:Black
* Power Source:AA, x 2
* Bulb:LED
* Output (lumens):120/30/.3
* Burn Time:30 Mins., 4 Hours, 240 Hours
* Submersible:66 ft.
* Carry System:Pocket Clip, Lanyard
* Batteries Included:Yes
* Switch:Tailcap On/Off/Momentary/Strobe
Может и не новинка, но таких ещё не встречал
Afonchenko Knives
Afonchenko Knives
Кварки выпустили новую серию, свято место пусто не бывает, недолго феникс держал пен-лайт, кварки ответили сильно целую кучу налепили :D
http://www.4sevens.com/index.php?cPath=297_332
Так же налепили всяких смазок, бальзамов, примочек и прочего )
http://www.4sevens.com/index.php?cPath=297_332_337
Я так понимаю их фонари модульные, можно все менять, или собрать? Хантер что скажешь?
http://www.4sevens.com/index.php?cPath=297_304
З.Ы. Чего то не нашел фоток феникса с Шот Шоу, их там небыло?
Afonchenko Knives
Afonchenko Knives
http://www.candlepowerforums.com/vb/sho ... p?t=258156 А вот тут и обзор новой линейки от (4/7)
OldRiy
Сообщение OldRiy »
Hunter
Участник
Сообщение Hunter »
На КВ пучок симпатичных цветных Преонов и Кварки из титана (в т.ч. и на АА с теплым диодом) по интересной цене (как я их пропустил? :? ):
http://www.knifeworks.com/4sevenslights-2.aspx
uhbuzz
Сообщение uhbuzz »
А всё потому , что они только появились :) http://www.knifeworks.com/newarrivals.aspx
Хорошая новость ((()))
