Hooke
Сообщение Hooke »
Kenguru13 писал(а):Я как бы камеру хочу а не мыльницу
Мы погрязнем в определении границ. :grin:
Kenguru13 писал(а):ШИТО?
Чем?
Я думал вы в курсе, что например Панасоник ЛХ3 и Лейка Люкс 4 один и тот же фотоаппарат по разному брендированный.
Пруф например тут
http://www.fastcompany.com/blog/ken-mus ... -panasonic
The Leica D-Lux 4 and the Panasonic Lumix DMC-LX3 are effectively identical products differentiated solely by design. They have the same sensor, lens, LCD, housing material, embedded software, battery, and battery charger. Both take identical pictures. They differ in small ways: the aesthetics of color (although Panasonic also makes a version in black, and Leica has a limited-edition version in anodized titanium), shape, surface, and that magical red Leica logo. Yet the Leica costs 50% to 150% more than the Panasonic, depending on the version. Leica itself seems very vague on the differences behind this spread.
There is one other key difference worth mentioning. The Leica has a loyal following that meets in various places online. To call them users is to undervalue them. These Leica advocates will even add attributes about the product that really do not exist. For instance, the Leica is often described as taking warmer, smoother, somehow better pictures, which would be amazing given the technology is identical. Moreover, I have seen the same feature described as an advantage on the Leica and a shortcoming on the Panasonic! At the camera store I have even had a seasoned salesclerk rave about an array of attributes and features in the Leica in direct comparison to the Panasonic, all impressive points, some true, many not unique to the Leica and some completely wrong and seemingly born out of this Leica folklore. It is a powerful brand that drives this level of advocacy.
И не только эта модель ;)
Hooke
Я выше несколько раз говорил что я имею ввиду М9 а не какуюто другую лейку. Возможно люкс 4 и не отличается от панасоника, я не интересовался :wink:
А М9 это полнокадровая камера с размером сенсора 36×24 мм :)
И я говорил исключительно про неё что это действительно отличный рабочий инструмент :)
Чего тут грязнуть, сенсор должен быть минимум АПС-Ц, в камере которую я куплю.
Как видите кандидатов нет почти, о чём я и говорю :-(
Hooke
Сообщение Hooke »
Kenguru13 писал(а):минимум АПС-Ц
тогда только беззеркалки, но да, лучше 100-ку
Boris376
Благодарил (а): 29 раз
Сообщение Boris376 »
Kenguru13 писал(а):Karl
Чтоб работал автофокус нужно покупать стёкла с мотором, маркировка AF-S, они обычно дороже, остальные обьективы будут работать только в мануальном режиме...
На Кеноне работают все автофокусные. :=(
Boris376
Это мы про 3100 говорили :)
Hooke
Видимо да. Но порою ещё, до этого был один кандидат д7000, теперь уже два :-D
Hooke
Сообщение Hooke »
Kenguru13 писал(а):Но порою ещё
Может Canon PowerShot G1 X?
18,7 x 14 мм не намного меньше запрошенного кропа, 2.8 дырка, но зато конструктив на высоте, поворотный дисплюй и кавайное колесико на месте )) и видоискатель как у дальномерки, синхронизирован с обьективом. :)
Hooke
Смотрел да его, но шумы как на д200, так что я ничего не выиграю, и картинка на фуджике мне больше понравилась, но у кенона есть зум и цена меньше...
Я его советовал Karl выше. Фотик похоже очень не плох. Но сравнивать с д7000 яб его не стал, а футжи слёгкостью сравниваю и фуджик не ударил в грязь лицом :)
Но фуджи я в руках не держал, всё может поменяться при живом знакомстве.
Нашёл ещё Samsung NX10, вроде интересный аппарат, и дешевле, но китовое стекло не покатит, а с нормальным обьективом думаю цена уже будет выше фуджи :-( А учитывая парк стёкол под никон, лучше уже брать д7000 ::dash::
Ненавижу выбирать :smile:
Aleksandr Afonchenko
Afonchenko Knives
Afonchenko Knives
Kenguru13 писал(а):Samsung NX10
Одно у него только плохо RAWы по 50 мегабайт ^^?^^
Afonchenko Knives
Afonchenko Knives
А я вам говорю, что из всех гибридников которые я перемацал, лучше SONY нет ничего!!! ИМХО
Codename 47
Ну сони только из меню настраивается, а жена 70% в мануале фоткает, так что не подойдёт никак, кроме того сони с нормальным стеклом сильно дорого выйдет. Кроме того нет башмака, видоискатель покупать отдельно, пыха отдельно, синхрокабель которым мы в основном для синхронизации юзаем вообще никак не подключить, из плюсов это то что через 2 переходника можно запилить никоновские объективы :-D Но опять же один из этих переходников дорогой. Так что для удовольствия возможно и ничё камера а работать с ней нельзя :-(
Ну это не проблема, а то что он уже на исо 400 шумит а 800 вообще несьедобен, вот это проблема, я сразу необратил внимания, щас равки глянул и расстроился :-(
Ну это не проблема,
Ага, только у него буфер маленький, серийная съемка в РАВ невозможна, покадровая тоже небыстрая :)
Понял, тогда тем более в топку.
Hooke
Сообщение Hooke »
Да, фуджик иногда выдает шедевры.
http://www.lovegroveconsulting.com/port ... index.html
::dash:: Ладно, я понял надо идти щупать и наверно брать :-D
Hooke
Сообщение Hooke »
И вполне себе портреты рисует на 35мм, главное правильный ракурс брать.
Неужто все необработанное? ДД поражает.
Hooke
Та ну не обработанное, думаю очень даже, но уровень. Не хотел приводить пафосные и явно проплаченные циаты этого фотографа, но снимки действительно у него отличные rt24
Так в Фотомагазине 1 его не было сегодня :-(
Будем искать значит гдеб пощупать :)
Hooke
Сообщение Hooke »
Пощупать полюбому, вдохновлять должен и тактильно, хотя уверен он такой, он вдохновит.. :=(
Karl.
Сообщение Karl. »
Hooke писал(а):Canon PowerShot G1 X
или Никон Д3100?
первого еще и в продаже нет...
http://rozetka.com.ua/canon_powershot_g1_x/p194266/
Первая же ссылка в гугле :-D
Из этих 2х вам стоит решить что вам больше нужно:
http://snapsort.com/compare/Canon-G1X-vs-Nikon_D3100
Вот примерное сравнение
От себя добавлю, что неоспоримыми плюсами никона есть несколько лучше качество картинки, выше рабочие исо, намного дольше держит батарея. На стороне кенона компактность и куча приятных но не особо важных свистелкоперделок :-D и вроде видео он лучше снимает, но точно не уверен, видео на фотике не интересует.
Karl.
Сообщение Karl. »
Kenguru13 писал(а):Первая же ссылка в гугле
Странно, еще вчера на Розетке цены не было...
Теперь, оценивая сравнение в цене, однозначно взял бы Никон, хотя бы по соотношению цена/качество.
Ябы чесно говоря тоже, выбирая из этих 2х :)
Hooke
Сообщение Hooke »
Очень похоже, что предпочтения тенденциозные. В том же обзоре, все с точностью наоборот. ;)
Сапог сейчас брать нельзя, он несомненно лучше, но поэтому и переоценен еще более значительно.
Если деньги не считать то брать Кенон, если считать и уже горит Никон, если есть время - подождать пока цена спадет, а она спадет...как минимум от выхода G2X :smile:
Как по мне, то наличие у Кенона опт.стаба, фазового АФ, высокого ИСО, почти не оставляет шансов Никону, в его активе только чуть больше ДД, чуть больше матрица, и чуть меньше шумов. Да и вообще сравнение некорректно, это разного класа, габаритов, идеологии и стоимости аппараты.
Karl.
Сообщение Karl. »
Hooke писал(а):если есть время - подождать пока цена спадет, а она спадет...как минимум от выхода G2X
когда же это будет?
http://www.canon.ru/For_Home/Product_Fi ... Shot_G1_X/
Hooke
высокого ИСО
А зачем они там если на них снимать нельзя? :smile:
Стаб есть в ките у 3100 :-D
Обратите внимание что кенон там набрал баллы за свистелкоперделки, ниодной реально нужной функции в его плюсах нет :-D
Единственный действительный его плюс это компактность. Так что брать его даже если цена упадёт только из-за этого :wink:
