Новинки от CRKT
Aleksandr Afonchenko
Afonchenko Knives
Afonchenko Knives
Re: Новинки от CRKT
Капец стоко дырок, палок и крючков что даже на нож не похоже (
grant333
Re: Новинки от CRKT
Сообщение grant333 »
http://campsite.com.ua/crkt-triumph-1030k.html (crkt 1030k triumph)
Кто знает , где эту модель можно в руках подержать ( в наличии нет во многих магазинах), и вообще какое мнение о нем?
хочу взять его или zt 0610 st
Re: Новинки от CRKT
Columbia River Knife & Tool
NIRK Tighe
When Brian Tighe saw Glenn Klecker’s NIRK folder, introduced last year by CRKT, he was inspired by the elegant simplicity of its minimalist design, stamped and folded out of two pieces of stainless steel. The resulting custom NIRK Tighe won the Most Innovative Custom Design Award at the 2010 Blade Show. Now CRKT has turned that collaboration into an affordable production knife priced at just $150 MSRP.
Instead of CNC machined titanium frames, the CRKT version uses stainless steel with blue titanium nitride coating and an exterior satin finish. Like the original NIRK, the knife is a lockback folder in which the spring, release bar and lock detent are all integral with the frame structure. The blue accents and intricate details make for a beautiful and striking knife.
The 3.875 in. AUS 8 stainless steel drop point blade has a bit of recurve to it. Large geometric cutouts serve as purchase for your thumb to one-hand open the blade, or you can use the flipper, which is even easier. A caged ball bearing system allows it to swing open smooth as silk. A removable stainless clip is provided.
NIRK Novo
Glenn Klecker's latest is the NIRK Novo, a bit smaller than the original NIRK, with a 2.75 in. sheepsfoot blade of 4Cr15MoVNi stainless steel. It is available as plain or combo edge in satin finish. Right hand carry only with a single thumb stud and a deep carry clip, the latter a nice improvement over the original. The frame and back lock are still a one piece design like the original, but there's no lanyard hole in this smaller version. MSRP is $25.
K.I.S.S. ASSist
Nobody will ever accuse the folks at CRKT of not having a sense of humor. The K.I.S.S. ASSist is the latest iteration of Ed Halligan's Keep It Super Simple knife design that has been a mainstay for CRKT from its earliest days. The added OutBurst assisted opening, with their patent-pending Fire Safe combination thumb stud and safety, does take some away from the simplicity angle, but they have done a great job incorporating it all into the basic design without mucking it up or adding a great deal of weight or bulk..
As described by CRKT, "when closed, the blade is safely locked by a special cam-over pin that extends from the assist spring. It cannot be opened until the safety button on the end of the thumb stud is firmly depressed and the thumb stud is nudged outward. It is both very fast, and very safe, because simply pressing the Fire Safe button does not open the knife. You must both press down and nudge the blade outward deliberately."
The AO spring and mechanism is covered by a thin sheet of carbon fiber composite inset into the frame. A Zytel guard serves to protect the single ground edge. The satin finish AUS 4 stainless steel blade is 2.75 in. long in either a drop point or tanto point and plain or combo edge. The frame is bead-blasted stainless with a removable stainless pocket clip/ money clip. MSRP is $60.
Shenanigan Aluminum and Shenanigan PPS
A pair of flipper opening liner lock folders from Ken Onion expands his offerings from CRKT. These are essentially the same knife offered in both a value priced model and a higher end model. Both feature at 3.25 in. classic Ken Onion drop point blade with a recurved edge.
AUS 8 stainless is used on the PPS, the higher end model uses CRKT's premium Acuto+ at 59-60 HRc. The PPS model features molded handles of polyphenylene sulfide (PPS) organic polymer with an inset liner. The Shenanigan Aluminum has a cold-forged 6061 T6 aluminum alloy handles, beadblasted and with a clear anodized coating. Injected molded grippy soft textured scales are inset into the handle.
Both are set up with a removable right hand carry clip and a lanyard hole. Both plain and combo edge is offered on both models. MSRP is $50 for the Shenanigan PPS and $100 for the Shenanigan Aluminum.
Onion Skinner
Ken Onion is a enthusiastic big game hunter and helps organize hunts for Paralyzed Veterans of America. For half a decade he's been perfecting his vision of the ultimate hunting/skinning knife, sending dozens and dozens of prototypes to guides, professional hunters and hunting buddies for testing. The result is not your father's hunting knife.
I'll let CRKT explain:
Quote:
Here’s an explanation of its unusual features and their functions:
First, the knife has a thin tip, with a slightly convex grind near the tip that minimizes drag. No caping knife is needed for detail work.
Second, the top of the blade has a pronounced “camel hump”. This allows the hunter to insert the tip under the skin and rock the hand back, which raises the tip up and away from the paunch.
Third, the tip has a straight section at an offset angle. This makes the knife a useful utility and cooking tool around camp.
Fourth, is the short 3.75” blade length. This is just the length of the average finger, which has proven perfect for the pencil grip favored by many hunters.
Finally, the Onion Skinner features a handle which has a deep finger choil, which greatly improves grip in slippery conditions. The thin cross section allows for less obtrusive carry while still locking in the fitted sheath.
The blade is Bohler K110 stainless steel with a satin finish, hardened to HRc 58-60. The very grippy handle is Thermal Plastic Rubber over-molded on a Zytel core with a textured finish of Onion's own design.
A lanyard is included, along with a very nice fitted leather deep insert sheath. MSRP is $80.
Shakaula
Ken Onion's take on a multi-function hunter's tool, the Shakulu combines two hunting blades that reach back to antiquity, a cleaver and the ulu palm knife. The 0.267 thick blade of 65MN high carbon steel, black powder coated, has a fairly high grind, providing a good slicing edge while retaining plenty of strength. A gut hook is incorporated into the spine.
You can hold the tool in a variety of grips, depending on what you want to use it for, skinning, gutting, chopping, etc. The ergonomic handle is polypropylene with over-molded dark green TPE plastic inserts. The polypropylene sheath is one of the best I've seen for this type tool, with a secure lock to hold it in, regardless of how it is carried. The lock on the sample we saw needs a bit of work to make it easier to use with cold hands or gloves on, which I am sure it will get.
CRKT notes, "the Shakaulu should not be confused with a brush cutter or hatchet. It is a much more sophisticated skinning tool, and the Razor-Sharp edge is not intended for such use." MSRP is $90.
M16-14ZER
CRKT has integrated a belt cutter and window breaker into its very popular larger frame M16. The belt cutter is cut into a somewhat larger flipper. A tungsten carbide window breaker protrudes from the butt of the handle.
The tanto ground blade is AUS 4, 3.75 inches long with a combo edge. It is equipped with AutoLAWKS safety lock. Scales are orange Zytel. The clip is reversible and can be used tip up or down. MSRP is $90.
Lefties Get Some Respect
CRKT introduced three new left-hand versions of some of their most popular tactical knives. These are the M21 G10, and 2 versions of the Special Forces M16, the M16-13SFGL and M16-14SFGL (in order below).
Re: Новинки от CRKT
кисс прийдется купить... :)
Re: Новинки от CRKT
Модель создана после накурки с Топсами? :)))
bfg11k
Re: Новинки от CRKT
Сообщение bfg11k »
Судя по фотам с ганзы, они там что-то более тяжелое принимают периодически :-D
Re: Новинки от CRKT
Все новинки на оффсайте (цены+ТТХ)
UPD: Вот, например из "невиденного":
Sampa - Designed by Flavio Ikoma
Последний раз редактировалось Сергей Сергеевич 27 янв 2011, 11:17, всего редактировалось 1 раз.
Re: Новинки от CRKT
Учитывая размеры и материалы удивительно гуманные цены...
McS
Re: Новинки от CRKT
Сообщение McS »
КИСС новый красивый. Еще бы цену старую :)
Re: Новинки от CRKT
А какие такие удивительные материалы в Сампе rt19 ? АУС-8 (ставшая уже банальной) и алюминий. Другое дело, что подшипники и стальная вставка на алюминиевый фрейм (как следствие - удорожание техпроцесса). Но Флавио Икома очень интересный мастер, а его нож Харриер, ИМХО, бомба.
Re: Новинки от CRKT
Re: Новинки от CRKT
Champ
Re: Новинки от CRKT
Сообщение Champ »
Onion Skinner нравится очень
Afonchenko Knives
Afonchenko Knives
Re: Новинки от CRKT
перефразировав суть работы компании у меня вышло следующее.
Родина требует героев а страна рождает дол...в
Это я о том, что задумки у них есть классные но исполнение как всегда муторное и закосяченое с кучей ненужных механизмов и запобижников (((
почти весь модельный ряд этой конторы я бы выложил на асфальт и написял бы, ну не написял, а обосс...л скажем так.
Сори что так откровенно но уж совсем все у них сложно и не нормально.
inakey
Re: Новинки от CRKT
Сообщение inakey »
имхо, конечно, но Shakaulu CRKTK900KKP очаровательна :-)
435 грамм неотразимости.
между прочим с открывалкой для пива, совмещенной с гвоздодером.
и новый K.I.S.S. ASSist. CRKT5650
с ассистом, ёлы-палы... :oops: куда они его вставили-то...
хотя, конечно, местами встречаются и дырчастые головоломки, при изучении которых я соглашусь с камрадом Codename 47. но только в отношении них :-D
Aleks
Re: Новинки от CRKT
Сообщение Aleks »
Столько хороших задумок, идей и форм было убито на месте и сходу никакущими материалами и термичкой не идущей ни в какие ворота. Так что соглашусь с Codename 47
Afonchenko Knives
Afonchenko Knives
Re: Новинки от CRKT
Сергей Сергеевич писал(а):UPD: Вот, например из "невиденного":
Как можно размещать такое паршивое фото на официальном сайте, это унизительно, просто наплевательское отношение к своим фанам ((
http://www.crkt.com/5330
Re: Новинки от CRKT
CRKT Ken Onion Shenanigan (http://www.crkt.com/Shenanigan6061)
Вовка-десант
Re: Новинки от CRKT
Сообщение Вовка-десант »
мне нравится.Надо дождаться отзывов.
Виталий
Re: Новинки от CRKT
Сообщение Виталий »
Последний раз редактировалось Виталий 01 авг 2019, 18:23, всего редактировалось 1 раз.
Re: Новинки от CRKT
Виталий писал(а):Только цена за аус8 в 100уе несколько великовата
Не совсем 100 уе - $61.95 :-D
Egor.
Re: Новинки от CRKT
Сообщение Egor. »
Ну вот :-) взяли blur и испортили...
Re: Новинки от CRKT
inakey
Re: Новинки от CRKT
Сообщение inakey »
CRKT K.I.S.S. ASSist
хотел спросить - в продаже ведь он уже есть - приходилось ли кому подержать его в руках? стоит ли он своих денег? вопрос к материалу и качеству конструкции... запал, зараза, в душу :-)
Re: Новинки от CRKT
Возможно, что-то уже было, возможно, некоторые не совсем новинки, но все же...
CRKT IKOMA KEYDASHI
CRKT IKOMA SAMPA
CRKT M16-14ZER
Изображение Изображение
CRKT Lake 111 Z2
CRKT Centofante Tribute
CRKT Grandpa's Favorite
Фото взял здесь - http://www.messerforum.net/showthread.php?t=101185 , там же короткое описание каждого на немецком...
