The Sonoran
- Nataliia
- Admin
The Sonoran
Итак, TOPS Knives на днях представили вниманию своих почитателей еще одну новинку с "тёплым названием" - Sonoran
( мы с вами знаем, что Сонора - одна из самых жарких и больших пустынь Северной Америки )
Тем самым бренд поделился с ножевой общественностью реализацией дизайна от Dave Holladay
The Sonoran
Overall Length: 7.75”
Blade Length: 3.75”
Cutting Edge: 3.75”
Blade Thickness: 0.160”
Blade Steel: 1095 RC 56-58
Blade Finish: Tumble Finish
Handle Material: Tan G-10
Knife Weight: 4.8oz
Weight w/ Sheath: 7oz
Sheath: Brown Leather
Designer: Dave Holladay
MSRP: $170
"The Sonoran Desert spans nearly 100,000 square miles throughout parts of the southwestern United States and northwestern Mexico. As someone who spends as much time, if not more, off grid in this region than he does in areas with modern amenities, it is easy to say that Dave knows what he is talking about and that this knife will perform well and accomplish just about any task you need it to to get by in that type of environment.
There are not a whole lot of things that Desert Dave can’t do so it is no surprise that he has added Knife Designer to the mix. Dave is a Primitive Skills Expert and is considered one of the country’s foremost educators in Stone Age living skills. The Sonoran is a working example of what his ideal blade would be. It has the looks of a traditional Puukko but with more of a trailing point than a straight back and a little more contour in the handle." (TOPS knives)
The Sonoran
Blade Length: 3.75”
Cutting Edge: 3.75”
Knife Weight: 4.8oz
MSRP: $170
- corsar_s
The Sonoran
Зачем? Наталья Владимировна, зачем?
- vld
- Майстер хайку
The Sonoran
Щось останнім часом “перси” в тренді
Це радує.
Це радує.
- Nataliia
- Admin
- corsar_s
The Sonoran
А заснуть теперь как?
- norther
- Експерт по фінкам
The Sonoran
Обух 4, спуски примерно 60% голоменей.
Сведен в 0.6? (будет вероятно).
Какой замечательный резак!
Нет, резак по дереву со сведением 0.5-0.6!
а обух- 4 с клином 95 мм -
под небольшой дезерт-бушкрафт!
(ну и сорри за небольшой ОФФ: про выживание в пустыне -https://www.imdb.com/title/tt2461030/ )
это с намеком: прикиньте битте по сюжету, когда может понадобиться там нож...
- corsar_s
The Sonoran
Это TOPS! Вы о чём вообще...
- corsar_s
The Sonoran
Самые лучшие ножи, самый большой ассортимент. Дизайнеров не меньше чем у CRKT.
Тока дорого. Один минус.
- Кузьмич
The Sonoran
Для TOPS - ікона надзвичайно вдалого дізайну
Але якщо це б зробив хтось з аматорів, або навіть майстрів форуму - то гадаю кількість табуреток би затмила сонце Було б і про задраний кінчик - слабке місце позбавлене можливості ковиряти та абсолютно незрозуміле, і про неправильні/зависокі спуски, і про топорне руків тощо... І піхви якісь простоваті, без родзинки
- Ramok
The Sonoran
Кузьмич, я б ще у цей перелік додав трубки, що тримають накладки. Зараз одним користуюся з трубками, вже є бажання їх залити епоксидкою, бо чистити фікс ватними паличками - занадто . Ніж сподобався, доречі
- Kart
The Sonoran
А если бы такой ножик представили публике китайцы... В воздух, были бы подняты по тревоге, не то что-бы табуретки, а целые мебельные гарнитуры...
- Ramok
The Sonoran
Kart, это ещё очень гармоничный дизайн, если брать во внимание, что это ТОПс
- Кузьмич
The Sonoran
Мені також, але за такі гроші точно ніколи не куплю.
Але якби ніж потрапив до мене - то скоріше за все зробив би таке:
- обточив накладки, зробивши іх тонкішими, але не виключаю ситуації, що потримавши в руці - залишив би як є Візуально товсті, але можуть виявитися зручними.
- прибрав тильника, або примнаймні б сточив його до кількох мм;
- можливо б прибрав горбика знизу руків1я, зробивши дугу від передньої до задньої частини накладок;
- пошив нові піхви фінского типу.
ЗІ: Критикувати завжди легше ніж зробити вдалого ножа
- Nerv
The Sonoran
после того, как ты начал собирать фиксы - ты вообще хоть один купшь?
как раз за задраный носик нож мне и понравился
- Кузьмич
The Sonoran
жодного не купив, і поки не планую купувати
якщо чесно то не зрозумв в чому прикол
22 сообщения
